Add/Remove Software on cRIO 9014 (unresolved discrepancies)
Hi everyone,
I am trying to use old controller cRIO-9014 to create a test project on LabVIEW. I installed student version of LabVIEW 2021, opened NI Max and formatted the previous data from cRIO-9014 (as somebody else was using this controller for their project). Now I am trying to add software on this controller (connected-safe mode & no program installed) but I am getting this unresolved discrepancies error (please find the attachment).
1. Is their any way I can get all the required stuff from the attachment without buying a licensed version of LabVIEW ?
2. Should I be able to find cRIO 9014 controller in Discover an existing target in LabVIEW software (I think No because cRIO-9014 is not compatible with my LabVIEW version-2021 but just wanted to confirm)?
Thanks in advance !
(1,555 Views)
this combination of LabVIEW version and cRIO will not work at all.
The last LabVIEW-version including drivers to support a cRIO-9014 is LabVIEW 2018.
Regards, Jens
Kudos are welcome...
(1,517 Views)
it might seem a dumb question but im new to cRIO and LabVIEW...
is there any possibility of making it work? like downloading the LabVIEW  2018 runtime, patch or something? if yes, I would be really thankful to know the proper way in details.
(1,436 Views)
