Add a VI in a VI
I am trying to add a VI in another VI (main VI).  I am able to do this by drag & drop, but the input-output terminals of the VI that is being added are not visible in main VI.  Any help is much appreciated.
(2,580 Views)
Accepted by topic author Sunnyabc
Did you actually assign any controls and/or indicators to the connector pane? https://www.ni.com/docs/en-US/bundle/labview/page/building-the-connector-pane.html
Have you done any LabVIEW tutorials? To learn more about LabVIEW it is recommended that you go through the introduction material, tutorial(s), and other material in the NI Developer Zone's Learning Center which provides links to other materials and other tutorials. There are also several Technical Resources. You can also take the online courses for free.
(2,573 Views)
