Add an offset to a chirp pattern
Hi everyone,
I would like to add an offset to a chip pattern, anyone has an idea of how to do that? I use a chirp pattern to plot the FRF of a system excited by a shaker but would need to apply a constant voltage to the shaker before running my chirp pattern (motion around an offset equilibrium).
Thanks in advance,
Alex
(3,994 Views)
Accepted by topic author shinagan
shinagan wrote:
I would like to add an offset ...
The numeric palette has an "add" function. That's all you probably need.
Wire a scalar offset to one input and the array ot the other.
(3,991 Views)
Worked perfectly well. Thanks!
Alex
(3,987 Views)
