Add arrays with shift register
HI,
I am trying to add 2 2D arrays using a shift register but it always give me zero out.
Here is a very simple piece of code to show.
If anyone can tell me what is wrong it would be most appreciated
Adam
(6,136 Views)
Accepted by topic author adamkse
You need initialize the shift register.  Otherwise, you are trying to add to an empty array.
edit: add snippet
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(6,133 Views)
Thanks, I see now. Didn't realise you had to do that.
P.S. Go Hokies 😉
(6,100 Views)
