Add attributes to root XML Node
I have seen this discussion, and the methodology doesn't seem to translate: https://forums.ni.com/t5/LabVIEW/XML-Attribute/td-p/791406
I'd like to set the attributes xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" and xsi:schemaLocation="/path/to/schema" in the root node. The original XML is here:
<?xml version="1.0" encoding="utf-8"?>
<root xmlns="http://example.com/XMLSchema/schema.xsd">
<child/>
</root>
The desired XML is here:
<root xmlns="http://example.com/XMLSchema/schema.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="C:\path\to\schema http://example.com/XMLSchema/schema.xsd">
<child/>
</root>
My attempt (one of many, definitely wrong) is here:
(4,167 Views)
Accepted by topic author ijustlovemath
Instead of trying to add or replace nodes, you can simply get the document from the "updated" node.xml root note add solution.png
There is an errata here. The order of the xsi:schemaLocation value should be namespace, path, NOT path,namespace as the snippet shows. I've updated it in my code, but it's minor enough that I'll be keeping it in this post.
(4,159 Views)
