Add channels of more than 1 DAQ to 1 task
I have a question about adding channels of multi DAQs to 1 task
Let's say I have 3 DAQs on my chassis. Dev1,Dev2,Dev3
Can I add all the AI channels of 3 DAQs to 1 task so I can configure all 3 at the same time and and aquire data concurrently from all 3 from the same task.
If it is possible then what DAQmx Write setting I should use? N channel N sample?
(3,655 Views)
I think it depends on the specific DAQ device you are using, I think the higher end devices allow you to acquire from multiple devices in one task (I might be wrong) but on the lower-end devices you must start one task per device (or measurement type).
If you think about it, the timing/acquisition rates possible might be different on each device and the DAQmx driver would need to be able to collate all the results together from different devices.
(blog)
(3,608 Views)
Hi Sam
Thank you for your response
The DAQs  I am using are all the same and they are PXI 6259. Do you know if I can group all teh channels to one task?
(3,563 Views)
Any help is really appreciated
(3,493 Views)
If you type the names of each device into a control, what error does it give you?
(3,472 Views)
Nope, that board will not let you put all three cards into a single task.  I've had to use multiple tasks, one for each card, on a similar card (same family).  X Series cards will allow multiple cards to be in a single task.  M Series does not.
(3,451 Views)
