Add different image to needle
I am using labview 8.5. I have taken one gauge control. What I want to do is, at every position its needle should have different image. Say if range of gauge is 1 to 6 then at each position needle will have different images. Can I do it?
Thank you
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,666 Views)
Hi Gaurav,
how many different needle images do you need? You can create as much needles as show need with different images and show and hide them depending on the value.
Mike
(3,664 Views)
Thank you
If you only have 6 positions to illustrate then a Picture Ring can be adapted using your own images for each value. With many more values that appraoch becomes un-workable. In that case you could use a Picture Control and render the image as required.
Ben
(3,646 Views)
Ben, is Mike's suggestion not a better & easier one than yours? Smiley Surprised
Since he can add the req no. of needles easily & also customise them with only a little bit of work.
Just asking...
- Partha ( CLD until Oct 2027 🙂 )
(3,638 Views)
Just asking...
 Maybe so. I'm just padding out the menu so the original poster has more options to choose from.
The picture ring can be dirt simple. THe Picture Control is a last resort option.
Ben
(3,634 Views)
Thank you every1 for your advice.
Gaurav k
CLD Certified !!!!!
(3,612 Views)
