Add i/o server to computer of customers
I have some problems with DSC Run-Time Engine. I install Labview 2010 and DSC module with OPC server. Activate them and build exe with one one function: Create and Configure IO Server Express VI. In my computer it is work with no problems. Then i did installer, and include there are all installers(check them) in additional installers. Install this installer in another computer, and try run my exe with one function? and there appear error:
Why this error is appear? maybe I build installer incorrect?
Message 1 of 8
(3,626 Views)
Hi rusl,
          The error is very clear from your attachment.It is missing sub VIs when you install it in another computer, check this properly.
Thanks as kudos only:)
Message 2 of 8
(3,617 Views)
but this vi is installed, when I install DSC module. So i think, then i install dsc run-time engine to computer of customers, this vi also must to install, isn`t it?
Message 3 of 8
(3,608 Views)
Hi rusl,
          you just try install dsc run-time engine to computer of customers also.And let us know further developments.
Message 4 of 8
(3,606 Views)
hi, I installed dsc run-time engine, I think so (how I can know it is dsc run-time engine or only run-time engine??). Then I try to run my exe with one function ( Create and Configure IO Server Express VI), and there is appear the error described above.
Message 5 of 8
(3,591 Views)
Hi ruslrusl,
It looks like you are trying to run a VI in LabVIEW that uses DSC functions.  The DSC Run Time engine was designed to run code that was built into an excecutable.  If you are trying to run a VI that has DSC functionality in it, you will need the DSC Development Module.  The error you are getting is expected if you don't have the development module.
Message 6 of 8
(3,555 Views)
But I have it, because I use functions of DSC module. When I build installers, I check as additional installers:
but when install this installer, i get:
there is nothing about dsc. why? can anybody explain it?
Message 7 of 8
(3,540 Views)
Hi ruslrusl,
If you go into the NI License Manager from Start»All Programs»National Instruments»NI License Manager you will see a bunch of software in the left column.  Under your version of LabVIEW, you will see Modules, and under that you should see Datalogging and Supervisory Control.  Can you tell tell us the exact phrasing of that module and what color the boxes are next to those modules are?  Actually, if you are willing to post a screenshot of your License Manager similar to what I've attached below WITH YOUR SERIAL NUMBER REMOVED I'd be glad to take a look at it and tell you what it looks like is going on.
Message 8 of 8
(3,526 Views)
