Add multiple selections for pattern label in file path control
Is there a way to add multiple selections to the pattern label in the file path control.
I can add a pattern label (Excel Files 97-2003) along with it's corresponding pattern (*.xls).  In the control, the user will see the line Excel Files 97-2003 (*.xls).  And the 2nd selection is All Files (*.*).  I would like to add a 3rd selection that says Excel Workbook (*.xlsx) to distinguish between Excel 2010 and Excel 2003.  Is this possible?  If not, multiple slections on file path controls would be a useful browse option.
(3,972 Views)
Did you try a search? This has been asked before multple times.
For example: Selecting Multiple File Types With Path Control
(3,960 Views)
