Add new inputs in array
I have a pressure sensor hooked up with sbRIO and I need to save the last three measurements in an array. In the following design I am only adding new inputs when they change. Every iteration updates new values from analog inputs of FPGA and I need to save last three elements in an array of fixed size.
I'll probably use this floor as a subVI later to extract elements of choice in some main VI. After calling this SubVI and wiring an input (random number gen for instance), nothing happens. I am doing something terribly wrong here please assist.
Regards.
(3,329 Views)
Another try. Seems to work.
(3,321 Views)
Accepted by topic author NapDynamite
Hi Nap,
three methods:
The solution to the bottom is the same as yours, but looks better without crossing wires…
(3,302 Views)
