Add plot using case structure
Hello 2 all!
I've searched the forum but i don't understand how to overcome this problem.
I still don't understand hot to handle the display of two waveforms using a case structure.
Let's say 1 have a case structure with 2 cases, thus 2 waveforms.
So in the 1'st case, a waveform is displayed. But how to overlay the second waveform generated in the next case over the first one  ?
Please give me an example !
Thank you very much 4 your time !
(3,995 Views)
Don't use a case structure if you need the waveforms to have more than one plot at a time.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(3,982 Views)
I have the code that generates the data and then a case structure. The code is only to show how to add two arrays of data together on the same graph.
This is an example only I do not need feedback on my coding from the peanut gallery.
Tim
GHSP
(3,976 Views)
If you post your code we may be able to help you with an efficent way to do what you are trying to do.
Tim
GHSP
(3,975 Views)
Ok ! Thank you 4 your interest, I will look at your example and get back to you later.Smiley Wink
Thank you again !
(3,971 Views)
