09-10-2007 07:43 AM
09-24-2007 06:55 AM
could you maybe illustrate this issue with a small example?
RikP - National Instruments Applications Engineering
09-25-2007 08:26 AM
The idea is to make a transient vibration measurement of a diesel engine, which steadily increases the rpm over a couple of minutes. In order to do this a multiple Fourier transformation can be done with the STFT vi which gives a power spectra to a colormap (as shown in the picture below). This works for short time domains like 10 seconds, but doesn’t work for a measurement time of 4 minutes.
Ideally the power spectra is written/appended to the colormap every second (visually).
I tried to append data with a shift register, which works for a simple graph, but couldn’t get it working for the power spectra.
Hans
09-25-2007 09:35 AM
This should work, I have essentially done this like the following:
for t=0 to T1
Take FFT.
Take Histogram (or sum of power inside) of fft (bin into frequency bins)- you will now have some more descrete version of the fft
Autoindex histogram out of loop.
You will have a 2d array with total power inside of a frequency bin on y axis and time on the Z axis.
Remember that the intensity map of this will be whibed out by large dynamic ranges so you might have to use a log Z scale or normalize the data in some other way.
Paul
