Add terminal nodes after creating message in actor framework
Sometimes I forget to add a terminal on my vi/dispatch template before creating a message out of it.  I then run into issues trying to recreate the message with the terminal added because it says name already used or w/e. Even if I remove the first message from my library it still hiding somewhere.  I end up having to change the name of the VI and then create another message.  Is there a way to efficiently add the forgotten terminal to the message type cluster inside that generated send message vi?
Studying for CLA.
LabVIEW, inherit from social media habits!
(1,437 Views)
Accepted by topic author CDuck
Lol of course, I had run into this issue for the last couple days.  The tutorial I am watching answered this question within minutes of posting this question
Here is the answer:
Right click the lvclass that the message is in.  Go to Actor Framework > Rescript Message
https://youtu.be/e2z4YTvH5zU?t=920
Studying for CLA.
(1,434 Views)
