Add the date in a name file
Hello !
In my project, the user needs to fill an array of file path.
I would like to add the date in every file of the array. How can I do that ?
For exemple, if the user write this : D:\data\file1 and D:\data\file2 in the first 2 file of the array, i want to rewrite this and have that : D:\data\file1_29_07_2020_09_13 and D:\data\file2_29_07_2020_09_13.
Thank you in advance.
(1,425 Views)
Use a function to get the file name:
  • Strip Path to get a file name as string and the directory.
  • Get File Extension.vi gives you the extension and the file name without the extension.
  • Path To String converts the entire path to string.
Use string functions to modify the string:
  • Format Into String, using %<>T
  • Or Search and Replace to replace the ".ext" with "data.ext"
Use Build Path to add the file name to the directory.
EDIT:
Do this in a for loop...
Please let us know what step is the problem.
(1,372 Views)
