Adding AI and AO channel to VI
I've started to work with LabVIEW a few weeks ago and already managed to create a few VI's. Unfortunately I recently have the issue, that I can't add AI oder AO channels from the Project into the VI. I used to drag an drop them from the Project file to the VI and it worked somehow. Do you have an idea what the Problem could be?
I use the NI 9066 Chassis with NI 9213 and NI 9205 modules.
The firmware is updated to the latest Version, but the NI MAX still tells me to update the Firmware. You'll find attached a screenshot of the NI MAX and the Project file.
If there is anything else needed, feel free to ask!
(1,873 Views)
Hi MiBa,
It offers to (try to) update the firmware, but you aren't forced to do that!
In the project explorer there is a "chassis cRIO-9066" visible, but there also seem to exist another chassis in the project!?
Do you try to drag&drop a ScanEngine item from one chassis into a VI running on the other chassis?
(1,868 Views)
Hey GerdW,
thanks for your answer!
Yes, I‘ve got two NI 9066 Chassis installed.( picture attached)
It‘s not possible to drag and drop the channels from the chassis in „pressure Box“ nor from the chassis in the „temperature box“. My VI runs currently on the computer. I‘ve already tried to run the VI on the chassis, but I still couldn’t drag and drop the channels into the VI.
It‘s interessting, that it stopped working from one day to another, especially because I changed nothing.
(1,836 Views)
