Adding Limits for Pass or Fail
I want to add limits with pass/fail to where the current readings show, however I am not sure what to do.
(1,657 Views)
Can you be more descriptive on the issue/ share us the files compatible with LV2020 or lower for proper suggestion
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(1,593 Views)
I cannot open your VI (most people here don't have LabVIEW 2022), but is this what you are looking for?
(1,587 Views)
