Adding NI VISA RunTime to a LabVIEW app on Mac using PackageMaker
I would like to create a Mac installer that installs NI VISA Run-time in addition to my application.  Actually, it would also include a 3rd party USB/UART bridge driver.  I'm trying to figure out how to get the NI VISA RT and the bridge driver included in my installer package.  I'm close--I can create a package that throws up 3 installer wizards. The problem is that both the NI VISA RT installer and the bridge driver installer wizards end with "Reboot" buttons.  If a user clicks either of those reboot button too early, not everything will be installed.
Has anyone come up against this kind of issue?
(3,687 Views)
Yup.  Install VISA after your program.  If you set your own installer to NOT require a reboot, then you'll only have the requirement after VISA installs.  This is how I did it I think.
Either that or I took out part of the VISA installer and re-incorporated it into my own installer.  I'm not in the office now so I can't check.
I so wish NI would offer an installer package for LV on the Mac.  Having to do this stuff manually is really not worthy of a $$$ product.
Shane.
Ps i should read better.  I see you have two packages requiring a reboot.  I think you can extract at least part of the installer package and re-incorporate it into your own installer.  I haven't done an installer on Mac for a while so my memory may be rusty.
Message Edited by Intaris on 11-11-2009 04:22 PM
(3,674 Views)
Hi
I am trying to package VISA RT into my app for distribution. Can you please share how you are able to accomplish this ? I am able to package LabVIEW run-time using the KB: https://decibel.ni.com/content/docs/DOC-26878
(3,259 Views)
