Adding Non-Labview Files to an Application Installer
I have several text files and *.wrl files that I am using with my application.  I want them to be included in the installation when I create an installer with the application builder.  My application works when I manually put the files in the appropriate directories, but this is too complicated for my end users.  How do I incorporate my data files into the installer?
(4,600 Views)
In your project, right click and select 'Add'. Then you can select a file or a folder. In the Installer>Source Files, you can then select where the support files get installed to.
(4,596 Views)
