Adding PCI-7833R to RTsi cable in MAX
I am trying to add my FPGA (PCI-7833R) to a RTSI cable in MAX.  The cable is connected in the chassis, and both the device and the cable appear in MAX.  However, when I right click on the cable and select "Add device to NI-RTSI cable," the FPGA does not appear as an option. What am I missing?
(3,051 Views)
Hi PTARlab
Thanks for posting.
It's not possible to add the RTSI card to an R series card using MAX, as this is really configuring DAQmx devices not FPGA ones.
Instead, you can gain access to the RTSI lines directly in a Project Explorer. After you have added your PCI-7833R to a project, right click on the FPGA target and select New...>>FPGA I/O. In the next window, you can select all of the RTSI lines and add them to your project.
Kind Regards
Chris | Applications Engineer NIUK
(3,011 Views)
Thanks!
(3,005 Views)
