Adding Queue to existing vi
@Hobbs23 wrote:
This is the third time I have heard that stacked sequences are not good, which gives me pause. I have yet to hear of any reason yet
The biggest reason is that they break data flow.  Data flow is the heart of LabVIEW programming.  When you break data flow, you eliminate potential for the compiler to do a better job.
Stacked Sequence Structures also limit reuse.  Imagine you have to do a wait after each step in your sequence.  You have to add that wait X times.  If you used a proper state machine, you could reuse that single state.
As already stated, sequence structures have to run linearly to completion.  If you use a state machine, you can abort early, skip steps, go back to previous steps, etc.
And going with a state machine that is string or enum based (either one works), you add self documentation since your case structure will tell you exactly what that state is doing (assuming you named your states well).
Message 11 of 28
(1,428 Views)
Hey RavensFan
Thank you for giving me the reasons for not using sequence structures. It seems even to me that those are plenty good enough.
You wrote: I don't understand what you are referring to by binary values in this situation or how sequence structures help that.
I was referring to a Case Structure as only a true/false state, but then you can add more frames after to expand beyond two states.
You wrote: While DOS 6.22 was great, that was back in 1994.  Comparing sequence structures to 23 year old technology doesn't help your argument.Smiley Wink
I wondered who I would draw out with this comment. 🙂 Consider it an abstract way of conceding that after hearing for the third time not to do something, that the knowledge level here is more than sufficient to start conceding to the mounting pressure. (We still run DOS 6.22 here on 1 machine. Funny, I never get asked for an update) 🙂
Message 12 of 28
(1,425 Views)
If DOS still works for your application, why fix something that is not broken?
=== Engineer Ambiguously ===
Message 13 of 28
(1,420 Views)
RavensFan
I may have made the mistake of lumping Case Structures in with Sequence Structures. Should I have included them in the conversation about Sequence Structures not being good choices?
Message 14 of 28
(1,410 Views)
Hello Yamaeda
I've been looking for the Event Sequence in my LabView 2009. There are some associated with Visa, in the advanced section. Will these work for what you were talking about?
Message 15 of 28
(1,405 Views)
Event STRUCTURE.  It is right there in the Structures palette.  Very hard to miss.  It is pretty much a requirement when dealing with GUIs.  With it, you can detect button presses, mouse movements, value changes, panel closing, drag and drop events, and more.
Message 16 of 28
(1,403 Views)
Not that I can find. It may be time we examined the premise. Not trying to be impolite, but completely baffled.
Message 17 of 28
(1,397 Views)
Let me guess: you have LabVIEW 2009 Base Development.  Before LabVIEW 2012, you needed the Professional edition to have the Event Structure.  If possible, try to upgrade.  Like I said before, the Event Structure is pretty much a requirement for a good GUI.
Message 18 of 28
(1,389 Views)
Look again crossrulz No InPlace Elements structure.  And old "S,L,G, Variable icons".  8.6 or earlier. but post 6.i ( which did not have FB Nodes or BD Decorations)
Message 19 of 28
(1,382 Views)
The OP specifically said they were using LabVIEW 2009.  And the NES was added to the Structure palette in LabVIEW 2010.
Message 20 of 28
(1,370 Views)
