Adding USI components
Good day
Here is my issue I have a program that records sensors the program functions as was intended, the data is saved in TDMS format.
The thing is that my associates only have LabView runtime installed, and the program requires the LabView USI components, and the compiled executable does not contain the USI components.
Is there any way to add the USI Components to the system or to include then when creating an executable , as our IT will not allow the an installer to be run from an unsigned source to make it a trusted application.
Thank you
(1,481 Views)
@n3ow wrote:
Good day
Thank you
https://forums.ni.com/t5/LabVIEW/error-2560-quot-LabVIEW-cannot-load-the-USI-components-quot/td-p/17...
(1,469 Views)
