Adding VI's to Function box
Hello all,
I just figured out how to add VI's to the Function box (the box that
appears when you right-click on the diagram) by adding VI's to an
arbitrarily-named folder in the Vi.lib\addons\ folder. But I just have
a quick question: how to I define the icons? I want to add several
utilities, and it would be easier to have different icons shown. I know
each VI has its own icon, but I'd like to know how to give each
directory in the addons folder it's own look. Thank you for your help.
Rick
(2,733 Views)
Since you know how to add VI's as submenu to the function palette (function box), just keep the right click on the submenu and select "edit submenu icon". Then you can edit the icon just as you edit VI's icon. Note than the icon must have no close rectangular around it if you would like to make the icon transparent as other submenu icon.
(2,733 Views)
