Adding WSN NI-9795 Nodes to a
I'm having troubles adding Nodes to the NI 97-95 Module. I was already able to add nodes before but i had some problems with the Crio (9074) and made a clean reinstall but now im not able to add nodes to the configuration. When I select the WSN menu under Devices and Interfaces in NI-MAX the buttons are grayed out. I already have installed the NI-WSN 15.0 Drivers. The node i'm trying to add is a WSN-3212.
I attach some screenshots of how the problem looks like in NI-MAX.
I hope you can help me.
Thank you.
(2,472 Views)
Hello joseguzb,
Can you tell us the blinking state of the LED on the NI 9575 module?
Fernando Becerra | Field Applications Engineer | National Instruments | CLA | CTD
(2,440 Views)
