Adding a name label in chart
Hello all,
I have 4 channels. whenever I choose a particular channel it should add to name label of waveform chart ( duplicate scale ) . for eg if i choose a resistance and voltage means only that name labels should be visible in the y scale of waveform graph /chart . could someone ready to fix this ?
 i have attached my vi
(3,497 Views)
Please find attached a VI hopefully this helps you out.
Note: I have manually created the Y Scales by Duplicating x4. As per this post https://forums.ni.com/t5/LabVIEW/Property-Node-to-duplicate-XY-Graph-Y-Scale/td-p/3338075
Kev
(3,294 Views)
