Adding a "Start" button
I have tried to add a "start" button to my VI without much success. I'm using LabView 8.5.1.
Currently, my VI is configured as follows:
I have a flat sequence structure with three "frames". The first two prompt the user for a filename and a location to save a log file to (these are in separate "frames") and configure the log file accordingly. The third frame is the bulk of the programme, running within a While loop.
I would ideally like a "Start" button that doubles up as a Stop button and stops the While loop from executing when pressed (and obviously, initiates the whole VI when it is a Start button!).
I have tried creating an "OK' button on the front panel, wiring this to the "enable" input of the "Enter Filename" block and also taking the wire outside the sequence structure, passing it through a "Not" block and re-entering into the sequence and while loop and terminating in the "stop if true" block within the while loop. However, whenever I run the VI within the developer environment by clicking the "Run" arrow, it instantly jumps to the "choose file path" dialogue, in the second frame, irrespective of the status of the Start/Stop button.
I hope this is clear enough. If you don't understand what i'm asking, please post and I'll attempt to clarify!
Thanks for the help 🙂
Message 1 of 16
(9,265 Views)
Seems to some basic stuff!!! but made complex by your explanation...
Just post the vi forum will solve it.
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
Message 2 of 16
(9,262 Views)
For that u need to change the architecture to State machine to contol ur states.
http://zone.ni.com/devzone/cda/tut/p/id/3024
ur flat sequence executes ur code sequentially u cant stop ur programme middle of the execution.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 3 of 16
(9,261 Views)
Try this:
The switch mechanical action is "Switch When Pressed" to give you the Start/Stop action.  The loop will stop when the stop button goes from True to False.  You'd put your code in the True case of the Case Structure and leave the False case empty and Bob will be your uncle.  You'll need to add something to make sure that the button is off when the VI starts (perhaps an Invoke Node at the beginning or end).
Message Edited by jcarmody on 05-26-2009 05:55 AM
Jim
Message 4 of 16
(9,247 Views)
Hi Thomas,
You might want to use an event structure (if you have at least the full LV version)
The following picture is not complete but shows the idea.
Regards.
Message Edited by Mathieu Steiner on 05-26-2009 01:59 PM
Message 5 of 16
(9,219 Views)
Get rid of the Stacked Structure and use either a State Machine or an Event Structure (better) as proposed earlier.
You can use the same button for Start / Stop.  Simply wire boolean output to a shift register and use a NAND (AND + invert) to alternate the output.
R
Message 6 of 16
(9,213 Views)
I think it is the Flat Seq Struct, Ray... Smiley Very Happy
- Partha ( CLD until Oct 2027 🙂 )
Message 7 of 16
(9,204 Views)
Old age has affected my eyesight..  Oops..  Well being 1/2 blind doesn't help  😄  I should change my avatar (again)
Thanks Partha..  😉
Message 8 of 16
(9,174 Views)
I tried jcarmody's suggestion but unfortunately it didn't work. I've attached the basic layout of my VI (it's very complex so have left everything out of the inner loops). Half of the method works fine, as in the VI doesn't start until  I click the "Start" button, but when I click the button again, it doesn't stop the script. I'd guess the problem is something to do with how I've wired everything up to the inner While loop.
If anyone  could shed some light on this it'd be much appreciated 🙂
Thanks!
Message 9 of 16
(9,163 Views)
The boolean wire that stops the inner most while loop gets its value from outside the loop.  So it will run exactly 1 time if that wire is True,  or run forever if that wire is False, because the value on that wire never changes inside the loop.  You need to get the value of the stop button inside the while loop.  One way is using a local variable of the stop button, but I don't normally recommend that.
Message 10 of 16
(9,158 Views)
