06-16-2004 01:58 PM
06-16-2004 02:35 PM
06-16-2004 03:56 PM
06-16-2004 04:55 PM
06-16-2004 05:14 PM
03-16-2007 06:34 PM
I just spent half a day configuring my laptop to interface with a TDS5054B scope from Tektronics. Couple of things to note:
1. Be sure that the firewall is not ON. My work laptop has extensive firewall protection; my personal laptop does not. That was crucial in getting a connection.
2. Be sure that the scope has TekVISA installed and that this server is RUNNING. There is a separate CD that came with the scope, and I had to install it.
3. Turn on the National Instruments VISA server.
4. Create a new interface by right mouse clicking the Devices and Interfaces key in the Measurement and Automation Explorer. If the scope is plug into the ethernet port with a CROSSOVER cable, and its VISA server is running, M&A Explorer should be able to find the device. You may not need to worry about knowing what the exact ethernet address is--unless you are not connected to the same subnet. Just select the TCP/IP resource, and things should naturally fall into place.
After I performed these steps (hopefully I didn't leave anything out), the VISA access was enabled to the scope. I hope everyone finds this useful. There is a link to the Tektronics website that was very helpful. I would place it here, but not sure that Tektronics would appreciate that.
John
