Adding an element to a LabVIEW Queue from a C Dll
Using LabVIEW 7.0, is it possible to add an element to a LabVIEW queue from with a dll written in C?
I'm using the queue as a synchronisation mechanism - it's a bit complicated, but I call a dll function which produces data. When it gets a new set of data, it sets an occurrence which my LabVIEW VI is waiting for (using WaitForOccurrence). Essentially, I need to add an element to the queue to indicate that the occurrence was set from within the DLL and not by LabVIEW (since I need to set the occurrence when I want to quit, otherwise it will wait for the occurrence forever!) I've tried lots of different ways to handle this, and this is the only scheme that works - at least, it works within LabVIEW, with one VI produc
ing data (simulating the dll). The trick is to now get it working with the real dll.
(3,116 Views)
There are other ways to do this, but if you are running Windows you can message into LabVIEW's ActiveX server and call a VI that enqueues data into your queue.
Good luck,
-Jim
(3,116 Views)
I'd recommend going another way. Once the C code signals it has data
using the occurrence, the easiest way is to have the diagram call back
into the DLL -- likely to another function -- and that function will
return the data. After you retrieve the data from the DLL, you can do
whatever you like, including enqueuing it.
Greg McKaskle
(3,116 Views)
