Adding data to a specific row in excel
Hi there,
                    I have problems with my data collection from serial read block. I get every time 16 bytes when I write certain command to my serial device. But after a continuous data written to excel, that is let say six rows of data and after that I get one byte of data which I do not want to save in current updating excel sheet.
For that now, I have taken a case structure with two cases, one case contains nothing when I read the one byte and another case contains the code(Spreadsheet file VI) for adding data to excel when 16 bytes received one by one. Still, I am not getting what I wish for. The one byte case adding zero to the current excel file at row 6 and then continuous with 16bytes of data in remaining rows and again after 6 continuous rows it adds zero and so on. I don't know why it is adding zero even i did not put any code inside the case of it.
How could I eliminate this adding of zeros?
Here it looks like in my excel sheet.
row1: 15 16 17 18 19 20
row2: 15 16 17 18 19 20
row3: 15 16 17 18 19 20
row4: 15 16 17 18 19 20
row5: 15 16 17 18 19 20
row6: 0                            (This when one byte reception case which contains no spreadsheet file VI)
row7: 15 16 17 18 19 20
row8: 15 16 17 18 19 20
row9: 15 16 17 18 19 20
row10: 0
Any help here around!
(3,171 Views)
Hi Peter,
why do you add a zero in your "one byte case" to your array when you don't need/want this?
Eliminate the "adding the zero" by deleting the according BuildArray function!
Anything else can be suggested after reviewing your VI...
(3,167 Views)
You misunderstood my point. I have no code inside the adding zero case. It adding by no meaning. I have only written in one case to add continuous data to excel when ever I receive more than one byte. If I receive one byte exactly, I would not like to append this to excel but currently my program is doing that.
I have added my code snippet which is not the current working code. I am out of access to my current code. But instead I have attached similar one. You merely assume that the data is coming form serial read block.
Thanks for your efforts.
(3,159 Views)
That piece of code is probably not even close to what you actually have since the True case is never executed. Why would you have a comma separated string wired to the selector and True/False for the two different cases?
If you can't post the actual code, just say so. Don't post something that makes no sense.
(3,141 Views)
