Adding harmonics
In the current waveform, I wanna add 3rd harmonices, then measure the level and show the waveform in the graph
Can anyone help me slove this based on my vi. Thank you!
(4,342 Views)
Hi LeoLiu,
You should be able to use another signal simulation but pass it 3x the frequency.  Once you have done this you can add the two signals together to combine them.  I have attached an example to show this.  Does this show what you mean?
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
(4,305 Views)
Hi james,
thank you for help me. When I added three harmonics, and I want show  each haromic level on the panel, which components do i need to use?
regards
(4,299 Views)
Hi Leoliu,
The harmonics will then appear as your peaks on FFTs.  If you need to extract them then search the pallettes for peak detector and this will return the peak values for you.
James Mc
(4,292 Views)
HI,James
What I mean is just show the each harmonic value in each block, and also have a componet to set the harmonics number, for example, I can set the highest harmonic is three, then I can see the 1st , 2nd, and 3rd harmonics on the graph and the level in block, I want see these automatically.
So can you help me to figure this out?
(4,263 Views)
