Adding into an array with an array and make a .csv file
Hi all.
So my issue is, that I want to make a .csv file with some recorded values, and I need to place a timestamp with date and time in it as well.
1) So my input 2D array which looks like this:
2) And my output array looks like this:
I am not sure if the approach is correct, but anyway you can try to see the .vi files.
So what I want is basically this result:
Because from there, I would like to generate the final .csv file like this:
(2,217 Views)
Hi Christian,
using InsertIntoArray almost always is the wrong tool…
See this:
Use BuildArray to build an array - or ReplaceArraySubset to replace elements in a predefined array…
(2,212 Views)
@GerdW wrote:
Hi Christian,
See this:
Thanks a lot, that was very simple... However there is just the last small details.
With this one, we are overwriting the header.
So I would like to get the output 2D array like this:
Any good idea to get that aligned? 🙂
(2,204 Views)
Hi Christian,
add the header line in the last step…
(2,202 Views)
Ahh, so just like this? 🙂
(2,197 Views)
I'd just use a Build array and add it in front, but yes.
Qestit Systems
Certified-LabVIEW-Developer
(2,164 Views)
