Adding labels to Array Typedef
I have a 2D array that holds values. It looks like this:
This array is involved in many different VI's, so I made it a typedef.  Now I can update it once and they all auto-update.  However, the labels in the type def do not update.  How do I get the labels to auto update as well?
Thanks!
(3,581 Views)
Accepted by topic author Hiphiphooray
In your TypeDef make sure it is set to Strict Type Def.  Otherwise, UI look is not carried to the points of use.
Quentin "Q" Alldredge
Chief LabVIEW Architect, Testeract | Owner, Q Software Innovations, LLC (QSI)
Director, GCentral | Admin, LabVIEW Wiki | Creator, The QControl Toolkit
Certified LabVIEW Architect | LabVIEW Champion | NI Alliance Partner
(3,570 Views)
