Adding multiple items to the middle of a Tree
How do I enter multiple items in a Tree at the same time, but not to its end? In other words, is there a way for me to specify the tag of the parent node to which the multiple items will be added? I currently use a for loop and add single items to the same parent, but that's very slow for hundreds of items.
Thank you,
Gus
(2,682 Views)
I don't have any experience with the tree control and I wouldn't be surprised if your suggestion is the only way to do this, but I can offer you one way which would likely speed it up significantly. Get a reference to the front panel and set its Defer Panel Updates property to T before the loop and to F after the loop. This will cause the display not to update while you're inside the loop.
Also, the LAVA forums has a code repository section where you should be able to find a library for working with trees which would probably be helpful.
___________________
Try to take over the world!
(2,680 Views)
Thank you. It's really a lot faster than what I had before.
Best,
Gus
(2,653 Views)
