Adding or removing an element from strict typ def cluster changes cluster default?
Hi All,
I have a big strict typ def cluster.  I put it into a vi with all default values.  The problem is, whenever I add or remove an element from the strict typ def, I find the cluster default values change, they are all shifted.
Anyway to solve this problem?
Thanks for any help.
Anne
Message 1 of 10
(3,902 Views)
Can you explain what you mean by "shifted"? Can you attach the type definition?
Message 2 of 10
(3,898 Views)
I made the suggestion of using a sub-VI to define default values in my Type Def Nugget as illustrated with this image.
LVOOP offer the ability to define the defauly values if you really want to avoid using a sub-VI.
Thoughts on what I suspect is happening:
IN a Strict type def the look is completely governed by the definition but the DATA is NOT! When type defs are updated the old version is complete removed and the new one is used in its place. So the data is not part of the type def. (except in LVOOP).
Ben
Message 3 of 10
(3,885 Views)
Message 4 of 10
(3,883 Views)
Accepted by topic author Anne Zuo
Could you attach the "ctl" instead? Also, what's your LabVIEW version?
Message 6 of 10
(3,863 Views)
sure. here is the strict typ def control.  My labview is 8.5.
Thank.
Message 7 of 10
(3,848 Views)
I cannot reproduce the problem in LabVIEW 8.5.1 and 8.6.
Message 8 of 10
(3,844 Views)
How comes?  My labview is 8.5.1.   Maybe you did it in a wrong way.  The screen copy in doc file shows you the steps.
I guess Ben is right.  Data type is part of the typ def, but not values.  He suggests to use subvi and bundle in names to define default values.  It woks that way.  The problem is:
*  I have too many big typ def.  If use subvi and bundle by names to define default value, it will take a lot of time.
*  even that way, if I remove one element from the typ def, the subvi for default value will be broken.
Thanks any way.
Message 9 of 10
(3,837 Views)
Well, there is no "wrong way" because you did not relly provide detailed step-by-step instructions. 😉
Still, after a bit of playing around, I was able to reproduce some anomaly similar to what you describe so maybe there is some problem.
Message 10 of 10
(3,812 Views)
