Adding picture to button makes button invisible
I would like to customize a boolean button with pictures for each state(true/false). When I did
"Import picture from clipboard->True", the button went invis as you see the Blank button 2 in the attachment. It works fine when I do a decal as in blank button. need some guidance here..
(4,215 Views)
Did you switch the button to see how the TRUE state actually looks like?
(4,192 Views)
I could not select the button or right click it to see the other state
(4,180 Views)
Your picture probably has some transparency in it that LabVIEW is picking up when you replace the True or False images. It's fine with a decal because the the original control's True/False pictures show "underneath" the transparency.
Edit your picture (with MS Paint or something similar) to remove any transparencies, copy, and insert into the control and see if it fixes it.
Feel free. Contact me for anything more,
    Pang
You too can be LabVIEW Awesome!
(4,172 Views)
What if you add a different (or even blank) picture of similar size to the FALSE case?
(4,157 Views)
Hey sorry I didnt notice it well previously. It's like the png has replaced the button in true state. Clicking it changes the png to blank button with no image and to false state
(4,149 Views)
Sorry, your reply makes very little sense as written. Did you solve the problem?
(4,138 Views)
