Adding plots programatically to mixed signal graphs
I have a VI where on draging channels from a tree on to a MSG  i expect it to display these dragged names as plot names.
Here is a detailed explanation of my requirement
I have N number of channels with a mixture of analog and digital data. I should be able to drag any number of channels at a time and before the waveform is generated i expect MSG to update the plot names respectively in their groups.
I could not find any property node to change group names or even add plots ( like XY graph for eg where we can add number of rows in the legend  and then update plot name)
(4,152 Views)
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(4,089 Views)
Works fine for XY plots also
Matthew Fitzsimons
(4,087 Views)
Thank you for the reply...But I want the same fuctionality to be implemented on a MIXED SIGNAL GRAPH (MSG)
(4,077 Views)
Don't know enough about MSG to know what works or not. This property may help you add charts. Modify the typeDef and let it auto-update
Auto-Update From Typedef Property
Short Name: Auto-Update
Requires: VI Scripting
Class: Control Properties
To Use: Create a property.
If TRUE, the control automatically updates when the type definition changes.
Matthew Fitzsimons
(4,055 Views)
