Adding timestamps in an LVM file
I am acquiring a analog signal using one channel of DAQ pad and saving them using 'write to measurment.vi' by setting its properties as 1)Header-one header only 2)X value(Time) coulmn as one column per channel.The saved file has the data format as this
X_Value Voltage Comment
0.000000 0.000305
0.010000 0.000000
0.020000 0.002747
0.030000 0.001526
0.040000 0.001373
can someone provide of how to add hours,minutes,seconds to the saving file.(If possible some example)
Thanks.
(2,648 Views)
The start time is in the header so you have all of the information you need. The format of the express VI is fixed and not easily changeable. You can of course, use one of the other file write functions. Export Waveforms to Spreadsheet File, Write to Spreadsheet File, the lower level Write to Text File, etc.
(2,643 Views)
