Adding to array for finding the bit error based on hamming distance
Hi every One
I designed below structure to find the BER based on hamming distance. It is not working.
I hope there is some professional KNIGHTS available.Smiley Frustrated
(4,455 Views)
At this point, you are just spamming the boards with the same question over and over. Very rude behavior and a behavior that tends to get you ignored.
(4,437 Views)
Think a bit more about how you're calculating your Hamming distance.
You're going to want to do a bitwise XOR. A simple Not Equal operating on the U8 is no good.
You can also take advantage of for loop autoindexing and leave the N terminal unwired.
There are probably more efficient ways of doing this but my initial guess was to use the Num To Boolean Array, XOR, Bool to [0,1] and Add array elements functions.
(4,433 Views)
Taki,
Please don't make it worse by responding to just the latest in a long string of duplicate posts.
(4,427 Views)
I just said it is not correct. Your behaviour is not correct.
(4,388 Views)
Hi Takki
I used Array to boolean but there is a error. My input is one dimention of array (0 to 255) and when I use array to boolean , there is an error.
(4,371 Views)
