Addition assignment operator & nested loops
I'm trying to implement this particular MATLAB code in LabVIEW and I'm stuck. I'm facing issues regarding the usage of nested loops and addition assignment operator. Can someone help me get started?
(2,046 Views)
Hi im,
To get you started you should take those "Training resources" offered at the top of the LabVIEW board!
  • Nested loops are really simple by nesting one loop inside the other one…
  • An addition function is found in the numerics function palette!
  • And that "assignment operator" will completely handled by LabVIEW once you learn the wonderful feature of autoindexing arrays at loop borders… 😄
Example:
A minor correction: the control labelled "k" should be labelled "n"!
(There might be problems due to the differences in array indexing between Matlab and LabVIEW…)
(2,042 Views)
Also, check the use of a Shift Register to propagate the partial sum from one loop iteration to the following.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(2,031 Views)
in my previous suggestion a shift register is missing.
Here's a (more LabVIEW-like) version which doesn't need that shift register:
(1,998 Views)
