Addition of Noise NI 6211
I was using N16211 card to record the FM modulated signal with 100kHz sampling rate. The data which I have taken 2 months ago was less noisy than recent data, the FFT data attached it is clearly visible. Why the noise increases almost 100 times
(2,933 Views)
What I understood from the images is that the noise was up over a wide range of frequency. Nothing such as an environment was changed between two measurements?
(2,895 Views)
Yes, experimental condition is just the same, but how the noise increases, NI card used to generate a TTL to record the FM modulation? Is it because of grounding issue ? The modulation frequency is 200Hz, but in  the demodulation I have observed a addition harmonic frequencies of 60Hz, 120 Hz, etc
(2,713 Views)
Hi Ramolemiss,
@RAMOLEMISS wrote:
Yes, experimental condition is just the same, but how the noise increases, … The modulation frequency is 200Hz, but in  the demodulation I have observed a addition harmonic frequencies of 60Hz, 120 Hz, etc
Do you live in a country where the main supply uses 60Hz AC (in contrast to Central Europe with 50Hz)?
Did something change inside/outside the test chamber about main supply wiring or larger devices (regarding power consumption)?
(2,661 Views)
Yes, I am working in the United States, 2 months back the demodulation doesn't contain these frequencies. Now, noise and these frequencies get added.  This 6211 NI card which also used for generating a TTL output with clock frequency 100kHz to trigger the camera when the camera needs external triggering.
(2,417 Views)
