Additional installer inclusion
hi.
i'm creating installer for one of my application and it is asking for additional installers such as ni lv runtime ,dacmx, ni-usi 15.0 but i can't able to locate the path of these additinal installers ,i want to know where these additional installers are  and how to add these installers to my application installer
Note: i'm using labview 2015 in my developement system,i have both dvd'd of developer suite and ni drivers.
(5,452 Views)
Are you pointing to your DVD when it asks to point to the directory of the additional installers?
Arev
CTO | RAFA Solutions
Certified-LabVIEW-Embedded-Systems-Developer_rgb.jpgCertified-LabVIEW-Architect_rgb.jpg
(5,390 Views)
The short answer is that you need your original install media in order to get a copy of the installer to be stored on your computer where LabVIEW can just use.  Otherwise you will always need the install media when you build an installer.
(5,386 Views)
After you have pointed to all of the drivers just make sure you remember to cache the installers in the installer configuration. Otherwise you are going to have to do this all over again which can be annoying if you have a lot of installers.
https://www.ni.com/docs/en-US/bundle/labview/page/caching-installer-distribution-components-windows....
(5,373 Views)
Accepted by topic author Rizwan00
yes i'm pointing my disc path when installer asks for path but still it is showing the dialogue that installer not found
(5,319 Views)
Hi Rizwan00,
                             Are you not getting options for selecting basic drivers and run time engines when you deselect "automatically select recommended installers"? Check the picture attached below.
Kamlesh
(5,211 Views)
hi kamlesh,
thanks for your reply,
This problem is resolved, When i used NI driver CD released in august 2015
(5,194 Views)
