Additional library for .exe application
Whenever starting, my built application (.exe) want to find a library.
Actually, distribution of the application doesn't include NI_AALPRO.Lvlib, but the application found it internally.
I would like to know how to set up in the application builder not to try to find it.
(2,894 Views)
You need that library if your app uses any of the analysis routines and when you create an installer, the lvanlys.dll will be included in  a data subfolder. My guess is that you did not create an installer. This is not a good idea.
(2,882 Views)
