Addon Error while Running labview web vi inn Internet explorer
HI
Greetings!
I wanted to access the Remote front panel of the LabVIEW VI with the help of html link generated using web publishing tool in LabVIEW, when i am doing so , I am Getting an error saying that " An add-on for this website is failed to Run" when i was trying to run the remote front panel in Internet Explorer version 11, i am using a Windows server 2016 Machine with LabVIEW 2019 version, i am not facing these errors while i try to run in other windows systems. i have gone through some of the links to trouble shoot these kind of Web publishing related issues, i have checked that LabVIEW Run Time Engine is installed, Plugins are located in the destination directory and also i run a regsvr32 command in cmd to register the dll , but i was unable to access the web vi, any help regarding this issue will be greatly appreciated
i am attaching the add-on prompting error for reference
(1,208 Views)
Dear SAIKIRAN_GOVINDU,
You get this error because 2019 version of LabVIEW you have does not support Windows server 2016 Machine. Here you can see the compatibilities of Windows servers with LabVIEW versions.
best,
anasei.
(1,129 Views)
