Addressing Issue with 9215 USB Module
My software is LabView 7.0. I have the 9215 USB module hooked up to the PC and am not sure how to input the address string in my application. I have the NI-Daqmx base drivers loaded on my PC as well. Please call me at area code 641-394-1074 which is at the PC location, and different from what is recorded in my profile.
Paul Krueger
(2,830 Views)
Thank you for contacting National Instruments.
For examples using DAQmx Base, please look under: C:\Program Files\National Instruments\LabVIEW 7.0\examples\daqmxbase . These should help you figure out how to address your devices.
If these do not help, and you would like to speak to an Applications Engineer on the phone, please go to http://www.ni.com/support/ and click "Phone NI" under "Option2: Request Support".
Sean C.
(2,818 Views)
