Adept Library problems
I try to use the adept library (adept library) to program some digilent boards, but after I followed  all the stept for installing I get this error (attached file). Anybody which had same propblem and found  how to fix it?
OS: Windows 10 64 bit
LaBVIEW 2015 64 bit
Thank you in advance,
Vlad
(4,009 Views)
Hi Vlad,
Since the Adept Library is actually created by the LabVIEW MakerHub, I'd actually recommend that you post your question on their forum here, where you'll more likely find users and support more specialized to this add-on.
(3,930 Views)
Hi Daniella,
Thank you, for the reply. I have posted on that forum, but nobody answered me. In time I found a work around solution, but I still want to solve this problem.
Vlad
(3,839 Views)
