Adjust the program to 125%
I normally when I do a program, I create a tab control of 1920x1080 so I adjust it to open in any monitor with that resolution. The problem is that when I open it in a laptop, it appears just one part because laptos have the scale of 125% instead of 100%. What should I do?
(947 Views)
Set Compatibility mode on labview.exe so that it ignores windows scaling.
Qestit Systems
Certified-LabVIEW-Developer
(912 Views)
The problem with that is that I see some sizes of strings and icons changed
(854 Views)
Did you change the DPI setting?
Qestit Systems
(817 Views)
Yes, I changed that, but when I have a small tab control it appears streched.
Anyway, maybe I can live with that
(809 Views)
Which DPI setting did you change? I'm on Windows 11, and changing the following setting resulted in there being no discernible differences between one scale setting and another. It also makes the window appear smaller compared to other windows with DPI awareness, but it's either that or the window does scale and things move around and stretch.
Spoiler
Redhawk
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
(776 Views)
I changed the same. Maybe the problem is how I center the program or something that I don in labview. Anyway, that is my only small window and the rest are full screen, so I won't change more things.
(753 Views)
