Adjusting to different screen resolutions?
I have a vi that serves as a display screen and I was hoping there was some way to adjust it such that it is always a certain size no matter the screen resolution. So that no matter whether the resolution is low or high I'd like to keep it the same size. The VI just has a big picture control on it so scaling all objects with the window size is completely useless,
(3,302 Views)
I would like to answer your question, but I need more info.. Would you like it a certain size in inches.. or in pixels. Would the resolution be changed at runtime?
Answer these and I can give you an answer
(3,302 Views)
I actually need it in pixels, I've played around with the window size properties and the main problem is that I can keep the picture indictor (which takes up almost my whole screen of the VI) and the window size constant no matter what the resolution is, but the BIG problem is that what's actually displayed on the picture just stays the same size (shows in the top left hand corner with higher resolution). Basically for low resolution I have a circle with it's center corresponsing to the center of the picture indicator, but with higher resolution even though the indicator can be a constant size the circle stays at whatever the pixel center was which is no longer the middle of the indicator. So if there is some way to make the circle bigger that's what I'm l
ooking for. Hope that clears it up, oh and I don't need to change resolutions during run time, just when the VI is started I'd like it to adjust.
(3,302 Views)
he circle
> bigger that's what I'm looking for. Hope that clears it up, oh and I
Something is producing the picture displayed in the picture indicator.
At this point it isn't possible to scale or zoom the picture in the
indicator after the fact. You will want to scale the coordinates
making up the picture itself. Scale the Rect wired to the Draw Circle
and move the center to be in the center of the indicator.
Greg McKaskle
(3,302 Views)
