Adlink cards not working with Labview?
I am using 2 Adlink cards, a 2205 and a 2502 and I cannot get labview to operate them properly. Even the example programs they supply do not work. Is anyone else having the same problem and/or does anyone have a solution?
(3,309 Views)
Paul_williams meinte am 6/16/2003 1:37 PM:
I had no problem to operate with the 7033 and 7034 cards from Adlink.
But i just used them only for a short while and switched the enviroment.
So i can't give you really deep details how to solve. But my advice is
that you contact the support for help - normally you will get an answer
within a day.
ps: Are the drivers for the hardware installed correctly?
(3,309 Views)
