Admiright Problem with Tdms Excel Automation
Hi
i have a problem with the TDMS Excel Plugin. I normally have now Administrator Rights on my Computer. So i got the Administator Rights to install the TDMS Excel Plugin. After i had the rights, i installed the Plugin and everything works fine. Then i wrote a VBA script with automatically imports TDMS Files and Copy &Paste Values in a new Excel sheet. Thes macro also works fine. After a while i lost my Admin Rights and i am a "Normal" user again. But with no more Admin-rights my macro doesn't work any longer. There is a error messange which tells me that " ...only a Administator can connect or disconnect the Plugin..."
The normal manual import with the Plugin still works.
Can anybody help me with this probblem?
Message 1 of 1
(2,561 Views)
