Adobe PDF Viewer CTL H
I have tried in vain to set my adobe pdf reader to READMODE but cant seem to get to the bottom of how it is done.
If however when I running my vi and I put focus onto the reader and press CTL H - this puts the reader into READMODE.
Does anyone know how I can replicate CTL H key press in code.
Many thanks.
Lee
(3,685 Views)
All this requires utilising user32.dll, luckily other people have already turned this into VIs for us.
Try using code from this example:
http://forums.ni.com/t5/Example-Programs/Programmatically-Simulate-Key-Strokes-in-LabVIEW/ta-p/35217...
It is fairly well explained, you will just need to make the window have focus. Here is an example for doing just that:
http://forums.ni.com/t5/Example-Programs/Programmatically-Move-Any-Window-to-the-Front/ta-p/3532516
Ian
LabVIEW since 2012
(3,657 Views)
Hello Ian
Thank you for your reply
I downloaded your code and ran and it works great.
So, in my application I need to 'iniitiate' CTL H. I put the focus on the adobe reader control and ran the keystrokes CTL DOWN 10mS - H PRESS 100mS - CTL UP 10mS, but unfortunately it didn't have the desired effect.
I can see when you put the output into a string indicator it works a treat.
Is there something I am missing here?
Lee
(3,624 Views)
Hello again Ian (quick reply to myself here)
I just needed to add a small delay before I applied the CTLH and it works a treat
Thank you very much for your help on this, it has been 'bugging' me on and off for a few weeks
Lee
(3,622 Views)
