Advanced Asynchronous TDMS data writing for LabVIEW RT
Hi all,
I have to log data into TDMS files from large number of channels.
Data logging should be done on NI PXIe 8135 real time target with LabVIEW RT operating system.
The data from all the channels should be logged within a cycle time of 1ms.
Question: Which Advanced TDMS mode should be best suitable for this task? Sysnchronous or Asynchronous?
It seems that Asynchronous Advanced TDMS logging is not supported by LabVIEW RT? Is this true?
Thank you.
Rahul
(3,790 Views)
Accepted by topic author Raul2203
Hi Rahul,
advanced asynchronous TDMS function are not supported on RT.
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(3,764 Views)
Hi Christoph,
Thank you for the confirmation.
regards,
Rahul
(3,759 Views)
